My main cigarette lighter isn't getting any power. I have not check the fuse yet. Has anyone had this issue in a 2008 jk?
Ck your fuse, I believe its a 15 amp, The fuse box cover is kinda hard to read the location. You have to turn it upside down. I had the same issue of no power. I believe it labled "Power port" or something close. Hope it helps
Checking fuse is always the first thing to do when electrical component is not working.
☞Sent from here☜
I think you may have a good laugh with this post. Check your fuse.
Sometimes, in the pressures of life, we get frustrated and we forget to apply common sense.
Slow down, take a deep breathe, and don't forget your common sense.
If its not the fuse, then the next thing to check would be the lighter assembly. But, I believe its probably the fuse. Someone probably plugged in a defective device and blew the fuse.
