Just got a 71 cj 5 has a 255v6 in it came with an extra motor turns out the fuel pump was bad pulled the other one off and it's arm is shaped different went to the part store to get on and they all look like the other style can't find one that looks the same as the one originally pulled out has anyone had this problem before is it just a new style will it work I don't want to mess up the motor thanks again I will post pics of the two styles in about an hour when I get back home
Thank you we have discovered another issue somewhere so problem solved electric fuel pump and regulator being installed as we speak
