Since I'm going to have to rebuild the frame on my YJ, I was thinking of working on the interior and changing my dash to a CJ dash.
My biggest question is hooking up the speedometer which has the temp and the fuel gauge combined with it.
If you have a 90 or older YJ, then it shouldn't be a problem. They still have a cable driven speedometer. 91 and newer are electric. You can get the older sending unit for the t-case and a cable if yours is a newer model.
If you want to get high tech, They now make a CJ style dash cluster that is GPS driven speedometer. But its kinda pricey. Last time I saw one it was around $450.
The temp and fuel gauges will be simply finding the correct wires in the original harness and transferring them to the CJ style cluster.
