1 - 20 of 119 Posts
Well I have decided to bite the bullet. After a few years of debate I have began the work to replace my body panels on my '76 CJ7.
Just like other CJ owners I debated between replacing the rust or installing a YJ tub. I have already done alot of work to my jeep and the quarters were something I chose to cover with bondo and ignore but the rust always came back. I decided to do the panels because one I found a original AMC panel and corner piece and more importantdue to the fact my floors are solid overall.
Here are a couple pics of the work. Alot to go. I started chipping away the bondo and rust once I got my diamond plate and fender flare off. Still plenty left to get too.
Retired Moderator
I agreed to help you put a winch on. You didn't say anything about body work. :p I was looking forward to wheeling with you soon but I guess it'll be a while yet, huh? :D
Looks like you made good progress tonight. :cool:
That might just be easier to do a body swap from the looks of those pictures.
Yeah......about that......I started messing with the winch plate but I just keep looking at the body. I'm going to do 1 side at a time. I hope that helps keep me from being bogged down with the work.
I am actually happy because I really thought they were worse than that....I know that is sad to say but there is alot of nice metal to weld too.
Well got more work done today. The flange on the floor boards is in good shape. Will make it alot easier to weld the new panel on.
The fender was off in less than 15 min. Only had 7 bolts holding it and very few things are attached on this side. Before I put the fender back on I will install my new headers and new steering shaft. :D
How are your body mounts? With that much rust I'd be carefull with both sides apart that the body doesn't shift/sag/etc before or while your are fitting your new panels. You might want to brace on side and tack the other replacements on. Gotta love rust....no mater how much you think there is you always seem to find that much more!!!:banghead:
-John
Discussion Starter · #16 ·
-John
Body mounts are good overall. I have one that is broke but not rusty.
I haven't cut or broke any tub supports so I think it should keep its shape. But I have marked stuff just to see if it does shift during the process.
I hear ya on the rust. Last car I worked on was a '29 Model A so this looks like shiny penny to that!
How were you cutting them off, Don't look like clean cuts till their totally off lol.
Just curious. Are you doing it on purpose?
Discussion Starter · #18 ·
They are held on by spot welds. I'm not really cutting them off per say.
The panel is spot welded on the front of the tub, the brace that runs from the top of the tub to the floor (door hinges bolt to), the floor and around the tub wheel well and where it connects to the rear panel.
It really doesnt matter how it comes off so I guess you could say I don't care how the metal looks I am taking off. I only care about what is left. So alot of times i would just tear it out of the way to get better access to the spot welds.
I am also not interfering with the internal bracing of the tub itself. I am leaving that intact and only replacing the skin/sheetmetal.
Does that answer your question?
Nick
Sure does. I wish I would of took it all off instead of doing individual panels :(
Look forward to seeing the outcome. Goodluck.
Discussion Starter · #20 ·
It isn't too late. :punk: It only took about 5 minutes of work and I was at the point of now return!
I should have the passenger side off today. I'll keep posting pics. Once I get the passenger side off I will start on the roll bar and a cage install. Will be alot easier to install with no panels on so it will be a week or better before I start welding the panels back on.
1 - 20 of 119 Posts
