Hey im a 17 year old that just got a 1985 cj7 with w 4.0 6 inline engine off a 2000 TJ. The problem is it starts but on the 3rd attempt what can the problem be?
Well you need to do give more information :
1. Fuel are you getting fuel ? Do you have to pump the gas on the 3rd attempt ? Do you have fuel injection ?
2. Is your starter cranking on the 1st attempt if not is your battery charged
3. Ignition is it old school coil ICM distributor ?
4. How does it run when started ? Any stalling ?
I need more information about you Jeep to help you .
I do not pump gas on the third attempt and its fuel injection
Ok it sounds like a fuel problem . I would start simple and clean the injectors and see if its a lack of fuel flow . Also check the fuel filter I always start with the simple stuff .
