All, I am at a loss on what the sound is coming from. If I am driving at low speeds, under 30, and take my foot off of the gas, there is a "click" sound coming from somewhere under the driver side seat. I only hear it with the window down. The sound is similar to when a motorcycle is at a stop light, in neutral, and steps on the gear to put it in 1st. There are times where it does make a slight jerk when it clicks too. I tried taking it to the dealership, but they said they did not hear it. if the window is up, you dont hear it. Is that a normal "Jeep noise" or something else. It never does it if the speed is over 40 and I release the gas pedal. It is only at speeds below 30
I'm so sorry. It is a 2015 JKU, 3.6. Automatic transmission. No lift, stock tire size (but Yokohama G003 instead of the Goodyear Wranglers it came with) I purchased it in May with 55462 miles on it, and it now has 57918 miles. Has not been taken off road at all yet.
The sound you hear the same sound I have. I also get the same sound sometime when going from P->D or P->R. I went as far as getting under the Jeep as it was running and having the better half move between the gears. The shift linkage is what I saw making the noise.
I never noticed the noise until I had tube doors on, and yes only at low speeds. From what others have told me its a normal "Jeep" noise.
Ken~
