1 - 12 of 12 Posts
on my 93 wrangler the clutch petal goes to the floor and doesnt feel as tough as it used to be but it works and shift gears and can rev up engne while clutch is in. my fluid is full in the slave cylinder and lines dont seem to be leaking or damaged. what could this be
youve been working your calf muscles really good?
k now i dont have any pedal and its not going into gear i cant tell is its the clutch or the master cylinder can anyone help pleae?
im going to bleed it today and see if its going to work if not i think it might be the master cylinder, hoping its not the internal slave if it is ill replace the whole thing lol - clutch kit master and all :banghead:
Discussion Starter #6
thank you jeep GOD! lol bled the clutch and got movement lol still feels a little week but i think ill replace the master cylinder next that should fix that ! :punk:
well check right behind the clutch pedal on the arm going into the master cyclinder. if there is fluid leaking then you have a bad master. i am not sure if your slave is internal or external but if its internal they are notorious for just going out, mine did twice. but anyways, if your gettin crappy pedal adn not going into gear all that great than chances are that is your problem. good luck if you need more help pm me i've gone through both several times
Discussion Starter #9
yeah i found that bad fluid im replacing it with a raybestos master cylinder hince I do work for raybestos lol
who sells that?
1 - 12 of 12 Posts
