I have a 1994 Jeep Wrangler. A few weeks ago when it was 12 degrees outside, I went to work & when I got in my jeep to leave the clutch seems loose...a lot of play in the pedal. As I was driving the pedal resistance went back to normal & I thought it was just doing that because it was freezing outside. Now that it is warmer, it still does it but not as bad. For instance, this morning I got in it to go to work & the same thing happened. My question is, is this typical clutch going bad symptoms? Or do i have water in the clutch line from freezing? I have the reservoir topped off so it is full of clutch fluid. Can I drain the fluid somehow & re-fill it? Any suggestions will be greatly appreciated. I just don't want to dump a few hundred dollars in a new clutch unless I have to.
