I have a 97 2.5 and I started hearing a noise when I am in neutral. when I press the clutch just slightly the noise will go away. I've had people say throw out bearing is going bad. I've read also that it could be a input shaft bearing. is that the transfer case input bearing or a transmission one?
Mostly old school..!
What does the noise sound like? If it's kind of a little rattle noise, it's likely a broken return spring if it just takes very slight pressure on the clutch pedal to make it stop.
If that's it, it really won't hurt anything....just annoying
If you have to push the clutch further than just slightly touching it, for it to quit, then it's probably the input shaft bearing of the transmission.
Sounds like tranny input
Clutch on opposite end tranny from transfer case so with tranny in neutral tc unaffected by clutch
Bad throw out is noisy with clutch pedal full down
so will I need to replace the whole input shaft? if I drive it like it is for awhile will it cause more damage?
