So tonight I was shifting from first to second and all of the sudden the clutch dropped to the floor like something broke.
When I went to shift into third the clutch was back but felt different.
Before when I shifted the clutch pedal would go all the way to the floor and release like normal about halfway up and start gripping.
Now the clutch doesn't feel like it able to be pushed all the way to the floor and it releases almost at the top of the stroke of the pedal.
The jeep is actually hard to start now because you have to push the clutch so hard to engage the clutch safety switch.
It actually drives fine the clutch just in engages and disengage in a different points than it used to.
I'm getting ready to go out to the garage and do a little bit of investigating any input would be greatly appreciated
It's a 99 2.5 4 cylinder the clutch has about 10,000 miles on it since I replace the engine
