drivin to work this morning I went to shift and the clutch went all the way to the floor and came back with no resistance whatsoever, I was unable to shift into gears too. I tried putting some fluid in it but it didn't help it leaked out immediately. it was coming from the slave cylinder, I changed it and when I added fluid it was pouring out the slave cylinder and from the tranny...I'm at a loss as to how to keep it from leaking from either. Is there a step by step procedure and also when I removed the old one there was no silver rod that was evident in the new one, is it in the tranny somewhere dancing around? Any and all advice would be greatly appreciated. Also I noticed that my clutch had started making noises a couple of days ago and the clutch movement became gritty and rough around the bottom 3-4 inches when I would depress it, it's my only vehicle and I need to get to work safely. It's a 2001 wrangler and I can still shift into gear but it's painful to do so, I feel like I'll be tearing up my transmission.
