Hello, I've been a lurker on the forums for quite some time. I just ran into a few issues that I have not been able to google answers for, and maybe you guys/gals can help me out?
2000 Jeep Tj, 89k miles, Sahara 5 speed
1. After getting everything back together I hopped in the driver seat to find my shifter very lose. I couldn't feel any of the gears, and it was not springing to the middle like it used to. Here is a video of where the shifter goes into the transmission, am I missing parts?
https://youtu.be/eMVcWyWBeaQ
2. My jeep will not start, it turns over but no fire. I am in the process of disconnecting all the wires, cleaning them with break cleaner/electronic parts cleaner. The battery was disconnected throughout the whole clutch replacement, would this make the crankshaft position sensor fail? (No check engine light)
3. When I press the clutch in, there is little resistance compared to what there used to be. When I took the slave cylinder out, I zip tied it immediately to the lift post and never touched it until re-installment. When I reinstalled it, I made sure it was centered in the throw out bearing bracket hole..thingy.. I would assume the vehicle needs to run to get pressure in the system resulting in giving the clutch pedal more resistance?
Thanks all.
Thanks all.
