I noticed that my 1st gear is getting harder to put in gear the rest are easy do I need to adjust my clutch and how can I do that
There is no adjustment for the clutch, it is hydraulic and self adjusting. You should probably check the fluid in it and see if it's getting low. It's the small reservoir next to the brake master cylinder, takes dot 3 brake fluid, in case you didn't know.
If it's just 1st gear that's tough, then a synchro is the likely culprit, too.
Never hurts to get under there and snug all the bolts either.
