So this morning I was at a red light and went to go. When I put the clutch in I had no pressure. I couldn't get it to do anything. It has fluid and the clutch is only 2 years old.
Mostly old school..!
Most likely slave or master cylinder as mentioned above, but before you buy parts, pull the slave out of the bell housing and see if it is intact. Sometimes broken ears on a throw out bearing will allow the slave cylinder to blow apart. If that's the case, it's drop the transmission time. Auto Zone throw out bearings are known for this.
Auto Zone (left), LUK (right)
