Knows a couple things...
The upstream O2 sensor is the one that can cause that kind of problem, ignore the downstream sensor on the catalytic converter which won't. At this point I'd be inspecting the O2 sensor wiring for problems like melting against the exhaust system or the insulation being rubbed through and causing the wiring to be intermittently shorted to ground.
