1 - 20 of 29 Posts
i was thinking of doing a 2 inch rustys coil lift with a set of 2 inch spacers. besides having to get longer shocks would i need anything else. Like a transefer case drop or new control arms?
YES, you will need everything that comes in a 4" lift kit except the springs. Relocation brackets, bump stops, control arms, T-case drop, pitman arm, ect, ect... Do yourself a favor and just buy a kit. You get what you pay for. Strearing geometry and driveline angle must be compensated for every inch of lift you do.
just buy a 4 inch lift from rough country, Its the cheapest and works good. I run it. It will actually be cheaper than buying the 2 inch lift kit and the spacers, and then buying everything else to make the spacer work.
Go with Rubicon Express, Rusty's or other quality system that includes new adjustible trackbars and control arms. You'll never regret it.
Im am running the regular 4" inch rough country lift. Not the x-series. Kit was super easy to install. A couple hours and it was all in, but i have experience and the tools but it should take u more than 4 hours. Simply instuctions came with it to. got it shipped to my door for 520. Check ebay, ebay has some pretty good prices, that can explain why i bought my jeep, winch , lift kit, lights, tires, and onboard air system and everything else on ebay. Ebay is almost as good as wal-mart.
Thanks Upinar i got trust in you man honestly that list of yours makes me jelous :) I'm just wondering whats the point of adjustable control arms though? I know the longer the control arms the better but you also have to move the ¿holder blocks¿ so i'm just a bit confused :) My explanation is since the longer the springs and the shocks, the longer the arms have to be to make up for the height but i'm hoping to hear a better explanation..
Thanks
Thats what i was thinking about. :) Thanks now i'm at much better shape in understanding it. I my self am thinking of tranny drop when i get a lift and call it done for that time and then sometime i'll get a sye and cv :) I hear motor mount lift is also really good but that will just help tug on the tranny and puling it even further up and forward so in the end its actually worse correct?
well, i know everyones gonna argue with me on this one. But i have 6.25 inch on suspension and i dont have a sye. When i put in the 4 inch lift kit, the tranny drop kit was enough to get rid of vibes. Then when i put the coil spacers back in, the vibes started, then i put in a 1 inch motor mount lift. then no vibes what so ever. I drive my jeep every day after an intense beating over the weekend. I rag on the jeep pretty hard, Ive gotten the back wheels in the air cause i hit a mud hole way to fast and the front dug. Ive bent control arm brackets and control arms. Ive even broke the balancer off the driveshaft. But havent had any problems with the driveshaft or transfer case. Yes, my pinion angle is a bit steep, but my output shaft is parrallel. No vibes what so ever at any speed. If something could happen to the transfercase cause of not having a sye. im sure it would of happened already. But thats just my jeep, every jeep is different. The funny thing is that i do every thing to my jeep that people say not to do.
1 - 20 of 29 Posts
