1 - 1 of 1 Posts
Hey all, I am in the process of swapping tons and coil-overs on my tj and am at the spring rate and ride height point in the rear. I decided to go with 16 inch coil-overs and ended up with a 150 tender over 200 primary spring rate. this made my rear sit much higher than i want with about 50%up and 50% down travel. I would like to have more of a 30% up-travel and 70% down travel. I was wondering if lowering the tender spring rate to 100 lbs/in would do it for me or if i have to get shorter springs and spin my adjuster down a bit. any input is appreciated. I also debated on building the shock towers higher to get the ride height shorter but realized this would not help the amount of shock shaft showing.
1 - 1 of 1 Posts
