Think it's for steering box , can't remember off hand
^ Correct. All four of the bolts pictured (including the one making contact with the spring) are attaching the steering box to the frame. I don't know of any cover. Is the axle centered under the jeep? How much pinion are you running?
No idea, the lift is pretty much 2" over stock, and i have an aftermarket front DS. i can try to get some measurements on the axel to see if it's centered, i have an adjustable trackbar, set if i remember correctly, just 1/2" longer than stock. The pinion angle doesn't look severe like some i've seeing, and i think it looks pretty much normal, almost stock, but i don't have a way to measure the angle anyways at this moment.
