1 - 11 of 11 Posts
I hear my coils making to much of a squeek for anything, especially when I get off the car. What can I do about it ?
What lift and who installed it? Are you sure that all of the spring isolators were put back in properly?
You can check the coils seating to make sure they are on the proper isolators, but if so a coil shouldn't make much of a noise unless it was say rubbing on something. Check for other components like bushings for a "squeak".
RK
Do you have urethane control arm bushings or urethane shock bushings?
1. like stated above if someone did not put the isolaters in properly the springs could squeak
2. stock control arms and a 2.5in lift could be a bad angle on the bushings could cause a squeak
3. could be sway bar end links
4. they ask about the bushings because the urtheane bushings get dry and can cause a squeak will not hurt the bushing but they do make a grease just for the urtheane bushings.
i think daystar makes some.
Another thing to check is if your coils are seated properly on the axle side. there is a little grove on the mount that the end of the coil sits in. If your coil is twisted at all it can cause some squeaking.
1 - 11 of 11 Posts
