Administrator
A little background first:
The 2014 model year seems to have quite a few that run warmer than normal for the 3.6, our '14 has been one of them.
Our factory radiator died at 2 years/45,000 miles and the thermostat shortly after that. I researched aftermarket radiators at that time and the only aluminium solution on the market was Mishimoto, which had terrible reviews. So we replaced ours with the OMIX-Ada factory style, which held up until removed at 95,000 miles. The fit was little off and it didn't "cool" any better than factory, we did a complete flush at the same time. So I wasn't completely happy with it.
At 95k miles I started on the 100k service items, aside from maintenance my goal was to get the Jeep cooling as well as our '16 and '18 JKs cooled. I replaced the water pump, belt, pullys, tensioner, PCV & plugs along with a flush. To my dismay temps remained about the same, maybe slightly better.
So there began my radiator research (again). I'd seen Cold-Case on the forum but didn't know anything about them. After researching a bit I decided to give them a shot.
Install:
Install is straight forward, no different than the factory radiator. Just pull the old radiator, swap the 4 rubber boots and install the new. Unlike my previous radiator this one mounted perfectly. It also came with all new hardware.
Results:
My drive to work is what I used as a comparison.
The first 5 days, temps were in the 90s.
The trip is:
  • 15 minutes of highway driving- normally around 217, NOW average 208
  • 5 minute standstill on off ramp- Normally will hit 228 and fan will cool it down. NOW 221 max.
  • .5 miles slow traffic- normally hits 228 and cools, NOW 211 average.
The next 2 work days, outside temps dropped to 70s.
  • Highway- Hits 203/204 then drops to 197 and climbs back up again. Rinse and repeat. This is pretty much exactly what our '18 does.
  • Offramp/standing still- hit 206 once, mostly around 203. Again pretty much like the '18.
So right now I'm a week and a half in and finally, after 5+ years and 100k miles, happy with how my Jeep cools. I'll check back in and report on how the radiator holds up, hopefully it lasts a long time :)
Obligatory pics:
Just read this. I have a 2014 too and it has always run hot on hills and hot days. This is a great review and great pics.
Are you still happy with the rad?
Cheers, Matt
Retired Moderator
Cheers, Matt
Reactions: heyjkmatt
Administrator
Cheers, Matt
So far, so good.
I haven't been hard on my Jeep this year as I'm in the middle of replacing the axles on it, so I don't have any experience yet under extreme conditions.
