I've done the "Nutter Bypass" however there are more than just the two wires on the ignition module. I'm curious if anyone has a real color coded wiring layout of where these wires go to.
Red
White
Green
Black
Violet
Orange.
I know that the Violet & Orange are the ones to bypass the ECU under the dash, but I've never seen exactly what the other wires do.
1st … Read this link and follow directions to update your signature to let us know what your working with, Better answers rather than supposition.
https://www.wranglerforum.com/f218/a-better-way-to-get-help-in-the-yj-tech-forum-2341475.html
2nd … With the nutter bypass were going to be looking at 87-90 so....
Open the link below to my FSM dropbox , pick your year, open it up, find the wiring diagram section and scroll through the wiring diagrams for your answers.
Good Luck and Welcome to the forum
Welcome to the Forum Admiral Glen,
I did the Nutter bypass when I first got my Jeep. It seemed to help a bit.
What really made a difference was when I installed a new timing chain and a HEI distributor. I did the chain and distributor at the same time and the chain was really stretched, so I don't know exactly how much of an improvement the HEI actually caused, but I haven't had to fiddle with it in 3+ years.
The one thing I know for certain, the HEI cured an erratic timing flash when using a timing light.
I seem to remember some Nutter instructions stating to twist the orange and violet wires. When I did my Nutter, I couldn't find violet wire on a spool, so I used blue.
I don't know what the other wires do, so I think your best bet is to follow the suggestions that Got it at last offers.
The more information you provide, the more accurate responses you'll get.
Good Luck, L.M.
Mine is a 1987 Wrangler 4.2 Engine.
Red
White
Green
Black
Violet
Orange.
I don't know of any color schematics. Any that I've seen are black & white.
In the FSM that Got it at last has in his signature, the the color of the wires in the schematics are marked. See the instruction page 2 in the Electrical Troubleshooting section. For instance:
18/GRY
W/TR = 18 gauge wire, grey in color with a colored tracer (TR) stripe
Good Luck, L.M.
