Has anyone here ran Super Swamper TSL Radial size 31x9.5x15 on stock rims with stock suspension?
What are your impressions in general of this tire if so?
Compared to 30x9.5x15 KO2's which do you prefer?
As I said in your other thread I have and I loved em...
As a bonus I got more compliments on that setup than I've had on all my other jeeps combined
Seriously considering it over the 30x9.5x15 KO2’s.
Will I have clearance issues with stock rims and suspension, I did find some stock rims and painted em up for it.
I ran the bias ones 31x10.5x15 but on 8" wide rims.
The tires fit under my 2000 Sahara with no issue, only rubbed on the flares on full flex up front with the wheels turned. This was due in part to extra backspace of aftermarket rims, and because Sahara flares were 1" wider than Sport. Offroad, the tires were without match. Indestructable. Aired down to 15lbs and my tj barely bent the sidewalls but they wrapped around rocks like rubber gloves.
Sent from my SM-G975U using Tapatalk
You may need a washer under each steering stop but otherwise they should work out really well for ya
