Hi All,
New Jeep owner and still learning the basics.
I got a soft top 2013 JKU and have been looking for hard top. I found a 2018 jku hard top but wasnt sure if there are any compatibility issues with using it on 2013 model. Any help is greatly appreciated
Retired Moderator
:welcome: to the Forum..:wavey:
it will be a direct swap.
Reactions: jdinny
Grumpy Old Guy
You're good to go. Just ensure the plug for the wiper/defrost is the same. You will have a wire bundle inside rear on the drivers side by the window strut. Pretty sure it is a male in the Jeep, female on the hardtop. Otherwise fitment is the same... assuming it is JK to JK or a JKU to JKU.
Thank you for the quick response. I will definitely check for the wire bundle for the harness. I was under the assumption that since it was softtop it didnt have the harness and i had to wire it if i wanted the rear defroster/viper to work. But i havent checked if the harness is already there.
That's where it would be. Look under your hood and see if a hose is running back from the reservoir
