1 - 20 of 117 Posts
The Bad Guy
I'm considering changing out my springs for heavy duty springs. The last 2 digits on my fronts are 14 and 55's in the rear. I'd be putting in 19's and 60's. I don't have a really good reason other than I like knowing I have a more heavy duty suspension. One of the first things I did was swap the stock shocks for Bilstein gas shocks.
I don't plan on adding a lift or larger tires. I have a 2 door with a soft top. Based on what I hear from others I would expect about a 1 inch lift. Am I wasting my time? These springs only cost $149 brand new for the whole set.
I dont think its a waste...youll get another inch of height for $149. If it makes you happy adding these springs on top of the shocks you already added, then go for it!
The Bad Guy
After much deliberation, I have decided to go through with the swap. I have the springs on order from a Mopar dealer. It will take a little while to get them since they are being ordered from the factory. I'm not in a hurry though because I'm waiting for slightly cooler weather to undertake this task.
In the meantime I've upgraded my floor jack and jack stands in order to handle the job. My old one barely got the tires off the ground, but was good enough for tire rotations. I made the mistake of putting my gas shocks on by "muscling them up instead of using jack stands on the frame and lowering the axle. By the time I hand compressed the last HD shock, I was spent.
I've always taken the anecdotes of added lift from spring swaps with a grain of salt so I plan on taking measurements before and after. I won't be adding spacers or leveling kits and will be keeping the same tires so I should get a true reading of before and after.
The Bad Guy
After much research that was conducted on another forum, it seems there is no set part number for the Rubicon or unlimited or unlimited with tow package. Some people with the same Jeep had different part numbers. the last 2 digits denote the stiffest springs. 19's for the front and 60's for the rear are the stiffest springs they make. They also appear to have more coils.
Generally an Unlimited with a hard top and the tow package had the stiffest springs. Rubicons generally had stiffer springs, but not necessarily the stiffest. Some people have switched to "Rubicon" springs and have gained absolutely nothing since they switched to the same part number or very close to the same part number.
:cool: Yo Dag, if you want, you might PM Hilldweller--
He swapped his 2dr springs with the Rubi and got some lift and stiffer action, pulling his trailer, I think he's pretty happy, well not happy, but satisfied !!
:rofl::rofl: JIMBO
The Bad Guy
Discussion Starter #7
FedEx guy brought these to the door around 3:30. So at 4PM I started grabbing the tools and got started. It was 90 degrees and about as humid as it could get. I got the first front spring done with no problems. Got to work on the second one. Lowered the axle with the jack and popped out the old spring. Started putting in the new one and couldn't get it to fit.
I worked and worked and couldn't get it in there. I was sweating like a pig and started feeling a little light headed so I took a break. I grabbed a Power Aid and sat on the step looking at the Jeep. That's when I noticed how stupid I was. I lowered the axle to let out the old spring, but didn't drop it any lower to allow the new one to fit. :banghead:
The backs went it without issue. I took measurements before and after from the ground to the bottom edge of the flares and from the ground to the bottom of my rock sliders. I gained a full 2 inches all the way around.
I went from 14 to 19 springs in the front and 55 to 60 springs in the rear. Looking at the new and old side by side, the new ones were definitely thicker and had about 1 1/2 more coils.
I didn't notice too much difference in the ride because I already had Bilstein HD shocks. My wife said she definitely felt the bumps more. It is sitting noticeably higher.
The Bad Guy
Discussion Starter #9
I'll get some on Saturday. It looks like we're going back to Assateague for the day.
:D LOL, The extreme heat can make you do $hit like that, been there , done that. Post them pics when you can.
:blunt: SLIM_SNOOPY :blunt:
The Bad Guy
Discussion Starter #11
OK, here are a couple of comparison pictures. I also picked up a set of Rubicon take-offs today.
Before:
After
The spring swap made a monumental difference for me ---- I wasn't out for height though and I think that's a bad reason to do the swap. I needed them for the additional weight I was carrying with bumpers, winch, & trailer.
The spring rate I have now is perfect for the way my Sahara is kitted and used.
The Bad Guy
Discussion Starter #13
Why do you say it's a bad reason? My main reason was that I wanted the HD suspenison. The lift is a pleasant side benefit. It certainly makes more sense to me than adding a 1" or 2" puck and risky possible warranty issues. I don't see this method causing any issues since the only thing under there are Mopar coils.
The Bad Guy
Discussion Starter #15
The springs have tags hanging on them. The last two digits are what tells them apart. There's a thread on JK-Forum that someone started in order to try and make sense of the different spring rates. Lets Solve the Stock Springs Question The fronts range from 13 to 19 and 60 is the highest for the rear. There doesn't seem to be any tried and true rule from the informal survey as to which Jeeps get which springs. However, 4 door hardtops with towing package are more likely to have the stiffer spring rates.
My X had 14's in the front and 55's in the rear. The new springs appeared slightly thicker and were at least 1 1/2 coils taller.
just checked, i have 17-57 springs on my 07 4dr with dual tops sahara and tow package (still not sure if i have the 4.10 gears i heard comes with that but i have the receiver and trailer plug...)
The Bad Guy
Discussion Starter #17
I doubt you would see a significant, if any, change since you have nearly the stiffest available. It was a big difference for me because I have a 2 door.
yeh i can understand that. i was just curious to see what i had. i dont plan on changing them out, especially now that i know im pretty close to the higher numbers and what they mean.
it definitely changed your 2dr :D i likey
1 - 20 of 117 Posts
