1 - 20 of 26 Posts
I am finally getting around to installing the Harken Hoister for my JKU hard top. I have a two car garage that also has two kids' bedrooms directly above it. It is a newer house, 5 years old now, and I noticed during construction that they used a manufactured joist system instead of solid lumber in the ceiling of the garage/floor of the bedrooms. Concerned, I contacted Harken and the rep stated that:
"I know nothing about ijoists and whether this system will work with those or not. If I had to guess I would say it will be just fine. Thanks"
I didn't see anything in the instructions online that explicitly stated not to use the hoister in that scenario, and with the somewhat vote of confidence from the Harken rep I went and ordered it.
In the process of summer vacations and general procrastination I somehow lost my original installation manual. Went to Quadratec to download the new one and now it says in the manual:
Warning: Do not screw into laminated rafters. They are not intended to accept fasteners. Consult rafter maker for recommendations. Screwing into laminated rafters may considerably weaken system, causing load to fall which may cause an accident, damage to property, personal injury or death.
Is what I have considered a laminated rafter? I am not sure. I do know that what is up there has an OSB or plywood layer on the underside of the joist/rafters as well as a layer of drywall on the outside of that. Could I instead use a liberal amount of toggle/anchor bolts to hold my 2x6's to the ceiling with enough holding power to keep the top secure?
I really don't want to do this wrong with my kids' bedrooms above. I have experience with construction and have no worries I can install this correctly, I just want to make sure I'm not compromising structural integrity.
Here is a photo I found online that shows what I saw when it was under construction. Note this isn't an actual photo of my particular house. It's just a representation of the type of joist/beam I saw.
I'm not a construction guy, but I would definitely get a professional opinion before you install the hoist.
Personally, if there wasn't some sort of bracing that could be done, I wouldn't go ahead with it. Again, get a professional opinion first before you abandon the idea.
Yes, what the picture is showing is engineered (plywood) I beans and they are laminated. The web, bottom and top chords are all laminated.
Don't know anything about a Harken Hoister, I made my own hoist but you should be able to attach (screw) 2x4's to the trusses and then attach your hoist to the 2x4's.
You are only lifting 80 to 95 lbs depending on whether you have a 2 or 4 door top. I'm assuming you have garage doors that weight a lot more attached to these I beams.
What you're showing in that picture is a rafter, what you have in your garage ceiling/upstairs floor is a joist. A ceiling/floor joist is made to hold weight significantly higher than that of your rafters. The best option would be to lay a 2" X 6" perpendicular to the joists and bolt the hoister to that. Unfortunately, you have rooms directly above your garage so you don't have the crawl space to do that. Instead, you'll have to reinforce the joist and go into that or truss between the joists and use that method. Either way, your going to be poking holes in the drywall ceiling.
The I beam shown can be used either as a roof rafter or floor truss.
An I beam with a longer web (between end cords) will have a greater carrying capacity but usually the limiting factors are spacing between I beams or the length of the beam.
In this case these beams or any I beam used as a floor joist should be able to carry the weight of a Jeep hard top.
4 door top minus the freedom panels is 95 lbs according to the manufacture.
According to my scale, the 2 door top with Freedom panels weighs 136 lbs. Each power / heated mirrored door weighs 62 lbs.
The back portion of the 2 door hard top is 90 lbs. The 4 door hard top is 120 lbs.
I just took mine off with a friend (we are both decent sized guys). I have a 2 door 2012 jk. But the most challenging part was balancing it. And it was heavy. Sure seemed like more than 120 pounds. Opening the back window did seem to help alot too
"...My neighbor has a spring scale... much like a fish scale, and I connected it from my pulley to my my top holder... I accounted for the weight of the top holder and measured total weight. Now granted, I had to keep it stable so I may be off a bit, but can't be by to much. I used the same scale for each door. The top weighs about 120 lbs. The front doors weigh in around 70 lbs a piece and the rear doors weigh in around 45lbs a piece. Total weight for all is around 350lbs. If you take if off while wheeling, you gain about a half inch of clearance. Every bit helps".
Ask 10 people and you'll get a different answer, but there is no bloody way the 4dr hardtop weighs only 95 pounds... as I've lifted it with another strong person. No bloody way, it's heavier. Who is right?
"The I beam shown can be used either as a roof rafter or floor truss.
In this case these beams or any I beam used as a floor joist should be able to carry the weight of a Jeep hard top."
That's what I said, with different words and clever usage of the / key.
I don't deal in second hand accounts. That being said I have never weighed the tops so personally I can't tell you with 100% certainty exactly what they weigh. I'm telling you what the manufacture of the tops state....80 for the 2 door 95 for the 4 door.
OK, thought you were saying that the I beams shown couldn't be used as a floor joist.
The picture you are showing is of roof trusses, not floor joists, but the concept is similar except they lay vertically on top of the plates on top of the walls surrounding your garage and provide support for the ceiling and your daughters' floors. They should be on 16 inch centers, as is common practice around the country (sometimes 12" centers). Get yourself a stud finder at Home Depot or other hardware store (not expensive) and locate the joists and mark them. Then attach two 2X6 boards across at least three of them (perpendicular) with hefty wood screws or lag bolts and washers after pre-drilling the holes smaller than the diameter of the screws/bolts. Space the 2x6s so you can attach the hoist to them. That will distribute the load and you can then attach your hoist to the 2X6s.
This is just a suggestion and you will have to verify. If any of this is confusing, consult or use a carpenter. Good luck.
From what I've been told by Boise Cascade (not the manufacturer of your i-beams), you will have no issues with mounting (2) 2"x6" boards approximately 44" on center apart from each other perpendicular to the existing engineered floor joist framing. The 2"x6" 'plate' should be attached to the i-beams with 3/8" diameter lag bolts into pre-drilled holes in the i-beam bottom cord.
I would suggest the 2"x6" span a minimum of 4 floor joists to help disperse the weight of the JK roof. I installed mine and added 3/8" diameter eye hooks as a secondary support system after the Harken Hoist was used to lift the top off the Jeep. I then ran some 1" wide nylon webbing from eye bolt to eye bolt with a ratchet to releive some of the weight from the hoist. Not that it's needed, but I feel safer knowing that's in place.
As to the concern of your kids bedroom floors having an issue, a house is typically designed with a 40 pound per square foot live load. Providing the house was properly designed, I would not worry about it. Just to give you a little bit of peace of mind, floors for car dealerships are designed with a 40 pound live load also. I doubt you will ever be parking a car in your kids bedroom. Though stranger things have happened.
The above information is supplied without any responsibility on my part, just a bit of friendly info.
Best..:hide:
Discussion Starter · #20 ·
Getting back into this conversatipn again. What safety concerns do you have? Are you concerned that a 80 to 95lb hard top is going to pull your garage ceiling down?
I was unfamiliar with the structural integrity of the bottom of these joists. I wanted to be sure that drilling in to the bottom side of them would not weaken them to the point of potential failure if, for example, a kid or myself jumped upstairs on the floor while playing around. I would rather be safe and know for sure than to have to dig my dead kids out of a heap of broken wood down in the garage. That's all. Just being a concerned father because I know my wife will have these same questions once I start putting it up.
1 - 20 of 26 Posts
