Both my rear control arm bolts are stuck on the axle side. The nuts are off both of them and they both spin freely there just rusted to the sleeve inside. I tried hitting them out with a hammer like I did with the rest but the space is too small between the hub and bolt. I'm open to any suggestions if I can't get it I'm admitting defeat and going to the mechanic for the first time ever besides inspection.
Discussion Starter #2
I also tried a Sawzall but broke 4 blades and it's not worth buying more blades when the garage will charge me like $50. Literally put the whole lift on myself in 6 hours then spent 6 hours trying to get 2 bolts out :(.
It means replacing the bolts but in cases like this a little heat works wonders.
