After replacing most components of my front suspension I found out that at least one the lower control arm bushings is worn out and probably is causing my death wobble. I am now wondering should I order a set of polyurethane bushings for the front axle or are the original rubber bushings better. I have seen a set of polyurethane here:
Energy Suspension 2-3106G - Energy Suspension Front Control Arm Bushings for 97-06 Jeep® Wrangler TJ & Unlimited - Quadratec
Should I replace all the bushings or only the one that’s bad? The trouble is that I am living in Costa Rica and have to order the parts in the US and that means the most expensive will be the transport so I want to make sure to order the right stuff one time.
Greetings from sunny Costa Rica
Thomas
