I recently noticed a slow coolant leak under my Jeep but cannot figure out where it is coming from. I see a small puddle of coolant on the bottom of the fan shroud but don’t see where it came from. I don’t see a line of coolant going back to the radiator and I don’t see any moisture around the fan clutch, nut or on the blades. I recently flushed my radiator for the first time since I bought it so I am guessing I unplugged a leak that the PO had sealed. I would rather find and fix the leak then seal it so I would really like to know where it is coming from. My first thought was the water pump, but I am not sure where exactly the weep hole is when its mounted, is it somewhere that I can see or feel? I flushed the radiator about 3 weeks ago and my fluid level is not noticeably lower but I can definitely see a wet spot on the dry concrete below the Jeep and the coolant dripping from the fan shroud down to the tie rod then to the ground.
Where else can this leak be coming from?
My jeep is a stock 2001 Sahara with about 102,000 miles.
