1 - 15 of 15 Posts
I have been getting a coolant smell for about 2 months while idling in stop and go traffic, or in the drive-thru
So far I have replaced
Water pump & Serp belt
thermostat
did a full flush and fill
I can't see any coolant coming from anywhere, and the oil looks good
The fan works and the temp gauge never go past the middle line.
any Ideas?
I would agree with the radiator cap as a first step. Mine would leak just enough to smell and occasionally see vapor. New one solved that until 100k miles later when I actually needed to replace the radiator.
Did you replace the factory constant tension spring clamps with worm screw clamps? Worm screw clamps tend to need more force for a good seal and, even then, it's problematic. It's not uncommon to see a small amount of vapor coming out under one of the worm clamps in the conditions you describe.
Discussion Starter #6
I was stuck in traffic last night, and of course smelled coolant. When I got home I lifted the hood. I for sure could smell coolant from the cap(I ordered one, it is on its way)
I also saw that the overflow bottle was spewing coolant all over (see image) any clue why that would be? It was directly below where the overflow opening is
Discussion Starter #8
Defective radiator cap and or the overflow bottle was overfilled.
Your overflow bottle has a minimum and a maximum level mark. Only fill it to no more than about 2" above the minimum level mark when cold.
It was right at the minimum mark when I checked it this weekend.
Hey all!
Doing a search for coolant leaks I came across this thread.
I have a 2010 Sport. I bought it used in 2012. At least as long as I've owned the vehicle I would periodically see vapor coming from the grill area when stopped at a light. The gauge always reads normal (once the engine reaches normal operating temp) and she's never overheated on me.
Thoughts?
If that's happening when there's rain, condensation or cool/wet conditions it's normal. Sometimes you'll see a lot of "steam" from condensation burning off. If it's happening when it's dry, or after the engine is at operating temperature, have the system pressure tested for possible leaks.
Discussion Starter #13
I (OP) have a 2008 JKUS. I did get a new radiator cap, and it seems better. Still not completely fixed though. I am going to try a pressure test next
Pressure testing the cooling system and testing the radiator cap would be the fist order of business after a visual inspection for leaks if I smell coolant.
Interesting. Thanks!
1 - 15 of 15 Posts
