Coolant only leaks sometimes, but when it does it leaks a lot. The other day I came from the bank and there was a small river running out. By the time I took it right home, it hasn't leaked since.
Water pump new and dry.
Thermostat dry.
And the hoses are new all radiator hoses changed. ....still leaks.
If you have a plastic radiator, possibly a crack somewhere that expands and contracts between the heat and cold?? Can you spot where the leak is actually coming from?
thanks guys. i'm def tired of buying coolant for this thing so I wanna find it right quick. I haven't been able to find where its leaking from just yet so maybe I will get a pressure tester and see what happens.
