I want to share my journey.
As some of you know, I’ve been struggling with extremely poor fuel economy numbers since last fall. As the weather got cold, my MPG dropped to 12-13 MPG around town; 15 MPG on the freeway.
For reference, my 2018 Sahara is a V6, automatic with a dealer-installed Mopar lift and 35-inch ATs.
Regearing
Due to the tall 3.45 gearing and the large tires, my auto wasn’t shifting past 6th gear. So last February I took a 1,000-mile road trip from WA to UT to have the gears swapped to 4.88.
My MPG getting there was a pathetic 12.7!!!
The gear swap went swimmingly and the Jeep regained full use of the 8-speed automatic. I really like how the Jeep drives and feels now.
Refueling in UT and WY
More interestingly, though, I noticed my fuel consumption improve significantly the moment I started pumping gasoline in Utah, jumping to 18 MPG on the first tank.
On the way back, with the new gearing, full use of the automatic transmission, and returning to our shitty west coast gasoline blend, I averaged 15.7 MPG. An improvement of 3 MPG.
However, driving around town over the past couple months my average has been going back down: it was 13.7 MPG early this week.
NO ETHANOL gasoline
I found a gas station at a nearby Indian reservation that sells 92 octane gasoline with NO ETHANOL. As an experiment I filled up the tank two days ago: my average over the first 50 miles appears to have improved by 3+ MPG to 17; mostly in city driving. If this holds, I should be averaging 18-19 MPG on the freeway. Similar to what I was getting in UT and WY.
I’d be very happy with that.
Moral of the story
If you are frustrated with your JL’s low MPG and are running out of ideas: see if you can find a gas station near you that sells NO ETHANOL gasoline and give it shot. My bet is you will see a dramatic improvement in your MPG.
Regearing
NO ETHANOL gasoline
Moral of the story
