I just got new tires, and I am getting so many different answers. What is the correct pressure for Ironman LT265/70R17 tires. It’s says on tire 80 psi max pressure. Thank you for the help.
32psi will be close. your door jam probably says 37psi. E rated tires are smoother at 28-32psi for sure. 80 psi is for 1 ton trucks at full load capacity not for jeeps.
Reactions: Kathil0u
x2 on the chalk test. I'm betting on 32'ish psi.... 80psi you could save money and just cut 4 circles out of wood and bolt them on :)
* I run 34 psi on my 315/70-17's but they are C-load.
