2013 JKU, has either a 2 1/2" lift, or just a leveling kit. I am not sure. But the front sits a bit higher than the rear. The shocks and springs, front and rear are a gray color. I would assume the factory stuff is black. Tells me they are not stock.
Can I just add a 3/4" spring spacer to the rear to get rid of the squat? or is that not the right thing to do?
yes that is a common cure for squatting. you might post some photos of your lift and someone will tell you what it is.
if springs are metallic gray, it could be Rubicon Express 2.5 lift. they had issues with some early model springs - they would compress with time. I had this issue, started loosing height, called them they admitted the problem, said, they changed the supplier for the springs since then and sent me newer model of springs free of charge - lifetime warranty
