1 - 20 of 44 Posts
I got stuck climbing that hill in the photo attached. I noticed my driver side front tire in the air and figured if it was on the ground I would have made it out. Is that true? If so, what can I do to get that kind of articulation? Maybe in the $500 range.
Currently I just have 35" tires on a 17" rim with a 2" lift.
I did back out and tried again and made it :)
disco your sway bar dude....cause it certainly aint there
I would. I don't know about what's out there for the JK's or if they have them already. What I do know is you need to disco your sway bar if you're gonna go play. I leave mine off, but I only drive my Rubi about 15% on the road
Disco or get a ORO swayloc....much better off road than no sway bar.
Yeah with discos you will walk over stuff you couldn't before and it also keeps your rig stable in the dirt. I attach mine when I'm done for the day but others don't.
I'm disappointed in all of you, a cheap quick disconnect kit is not the answer. It's obvious from the picture he needs 37's with at least 2 more inches of lift, lockers front and rear and a 10,000 lb winch to conquer that obstacle. Now get shopping!
:punk:
I have Teraflex and they are awesome. Easy to come off, require some work to get back on. It helps if ou have flat level ground upon attempted reassembly. .... that's always in abundance at the trail head no?
Rubicon :popcorn:
1 - 20 of 44 Posts
