1 - 10 of 10 Posts
I recently had the dash removed to change my evaporator and heater core. Got everything back together....now I can't get the interior lights to go out.
It seemed like the drivers side door switch was intermittent, because if I pressed it with my hand the lights would sometimes go out. I cut the two wires going to the switch and joined them together but this did not work.
You can temporarily remove fuse #4 behind your glove box to completely disable the dome lights.
To ultimately fix your issue, it sounds like your switch needs to be replaced.
Knows a couple things...
My bet is the rotary dashlight dimmer switch was left rotated fully so it is clicked on. Pulling fuse #4 behind the glove box won't shut the light off if the dimmer switch was accidentally left clicked on.
rotary. Switch definately NOT on. Is there a connector under the dash that connects this circuit....
Twisting the wires together will turn the light on..... seperate them for off
It didn't matter, wires together or separated still the same out come. I also checked the switch with an ohm meter and it's working fine
If all was working before you took the dash out - you made something change.
Putting wire together will not work, it make circuit closed - door closed {switch [circuit] open light off - door open {switch [circuit] closed} light on.
Fuse 4 is the door switch disable, if you pull it and the light goes out it's the switch (either) if the light stays on it is the main light switch/dimmer.
I re-soldered the wires for the door switch that I cut.
When I pulled fuse 4 the lights went out.
I doubled checked and re-seated all connectors behind the dash and everything seems to be working correctly.
I think the problem was caused by the white connector (that goes to the instrument cluster/gauges) being loose. The wires for the door switch(es) are routed through that connector.
1 - 10 of 10 Posts
