New to the jeep world, just bought a 2011 wrangler, can't seem to get the courtesy light to work, the dome light will not come on even when I turn the switch on the steering colum on, it will come on when I push the buttons on the light on. Am I missing something??
Do you mean when you open the driver door the dome light will not come on? If so im also guessing the radio does not continue to play when you turn the ignition key off either? If this is the case you may have a bad door wiring harness. I replaced mine for the issues described.
I recently read or heard about a wiring issue that affected the heated mirrors. Check it out ,it ma kill two issues for you and for free too. I bought my door harness.
