No need to worry about it, it not into the manifold it's self, just sends warm air to the air cleaner on carb'ed 2.5 for warm up.GGDelivery said:I have a 95 2.5L. Here what my manifold looks like.
I've been searching for a replacement manifold and all the original replacements look like this for the 2.5L
What is that extra hole in the fwd manifold? I for sure don't have one nor anything else on my engine that hooks up to that..... And almost all replacement manifolds for the 95 2.5l have that hole.... I'm so lost
Any good welding shop can most likely repair for you, just remove and take to them. They should be able to repair in just a few hours, they drill a hole at each end of the crack and then heat the area up and weld with a cast iron rod and let it air cool. Takes longer to get it ready and cool than to repair.GGDelivery said:While cleaning my fuel injectors today, I noticed my exhaust manifold has a crack in it..... I'm pretty sure my cat is clogged as well.... Any ideas on what affordable replacement parts I should get to replace them?
95 wrangler 2.5L
