Ive been searching on this to no avail, but curious if theres anyone out there that has modded the crankcase vent tubes that recirculate the crankcase gasses.
Im thinking of just slapping on a little filter on the front one, but not sure if I should do anything with the rear one.
What for? Crankcase ventilation sometimes have a little foam filter to catch oil vapor and keep it off the main air filter when it is piped to the dirty side of the factory air box. Is that what you mean?
the tube with the valve goes to your intake vacuum which actually sucks the air and gases out of your engine..without this you would be more apt to have leaks because of pressure in the engine
