K - I'm installing the cb and running power to the battery. I'm going to ground to the battery. Do I need to disconnect the battery (negative off then positive) to attach the positive terminal or can I just attach straight to the battery? I've watched a couple videos and they attach straight to the battery without taking off the negative. What should I do?
The book answer? Disconnect the neg terminal, attach your pos line, then hook up your neg cb lead to the neg terminal, then reconnect the neg terminal to the batt.
Unhooking the neg breaks the circuit, no need to disconnect both.
Man, thanks for showing an idiot newb some mercy - I got shocked pretty bad when I was little so I'm terrified of electricity.
All good, and besides cars only have 12v. It takes over 26v to cause harm.
Man - got through all that and the CB wouldn't turn on...oh well...I will have to find out tomorrow if I crimped poorly or if this old rusty CB is dunzo
