My cruise control stopped working randomly. The cruise light comes on and off but I can't set my speed what would be the problem
It could possible
▄▌ee▐▀
Does your air blow out of any other positions other than defrost? If it's a vacuum leak that is sometimes affected as well.
Easy enough to check the vacuum connector that usually falls off right below the throttle body.
Mine wasn't working awhile back neither did the horn, it turns out it was the clock spring once it was replaced everything worked again.
(never mind... clicked into the wrong area)
