I have a 2017 jku. When on highway with it on and set. If I hit a med bump it kicks off? Anyone have this happen.
I had a 2010 that it never happened.
Yep seems to be common thing. Some claim it's caused by the traction control. Maybe drop the tire pressure a pound or two if it bugs you too much. Mine seems to do it only when my tires are above 40 psi, only one bump on my commute does it.
Thanks
I had this happen on another vehicle, and it ended up being the brake switch, attached to the pedal. The bounce would bump some contacts, and it would think you tapped the brakes. Might be something cheap to check.
