Just installed MC 3.5 game changer with all 8 adjustable arms with 35 BFG KO2 and got an alignment. I'm just curious if anything looks off. I know my camber is off but I'm not sure if .3 is something to worry about. So if someone could look over this I appreciate it =]
The only factory adjustments on a Wrangler are Toe in/out. If it's not pulling and drives ok, I wouldn't worry, there are no camber adjustments that can be made.
Commercial Member
Maybe dial back that FR Caster down by a hair?!?! One full turn of the adjustable end will probably get you right there. Usually the FR has approximately 0.2 more Caster to negate the crown on the road...
he has plenty of caster adjustment
True, I don't know why I didn't read the part about the adjustable control arms.
