I am installing my Currie Front Lower Control Arms and my kit didn't include the larger washers that are suppose to fill the gap inside the "horseshoe" on the axle side. (I am assuming I should of have them based on this quote from the directions "The larger washers supplied with the lower control arms are for use with the the front lower arms where they bolt onto the axle housing").
My question is... Do I have to install the large washers to compensate for the elongated hole or will the pinch force be enough to keep things in place?
By the way, I am very pleased with the quality of the Currie Arms! Every time I look at them compared to the stock ones I am removing I giggle a little
