1 - 14 of 14 Posts
Ok so I took the headliner idea from this post http://www.jeepforum.com/forum/f12/soft-top-insulation-best-cheap-mod-1305553/
and then decided to make a sound bar since my little 5.25" speakers suck. It will have 6.5 and 4x6s. Here is what I have done far.
MDF it is cut to sit on top of the windshield and then all the way back to the roll bar. I had to cut the corners so my top will go over it because I have a cab top
If I could go back I would have waited to get the right tools so I could have cut my rings out of MDF and not card board
Waiting on the fiberglass to dry...
to be continued......
If you ever watch shows like Inside West Coast Customs, instead using fiberglass like you did, they staple a felt-like material over the speaker rings, and then brush on fiberglass resin. Once that has hardened, they spread several layers of plastic filler to smooth it out. The way you are doing it with many pieces of fiberglass, it will take a lot of filler and work to smooth it out. Plus, it will end up being much heavier.
Fleece is the material you want to use. It is a little stretchy and will result in a smoother surface. Here is a good write up on how to do it. Hope it helps.
How to Make a Fiberglass Subwoofer Box
Felt is stretchy also, it's just a little thicker. And actually that is actually one of the how to's I am using to help with this build. My build is going fine now. I was just a dope at the start and was in too big of a hurry. But now it's going on fine.
In west coast customs. They dont just use felt or fleece with fiberglass resin over it. It's not sturdy enough. They apply Fiberglass Matte like in the how to that jay_in_cohio posted. I just got a sheet of fiberglass cloth and cut it into strips. It's still smooth and once I put bondo over it, it will still smooth out.
This is either going to be awesome or a train wreck. Either way, I can't stop watching. Someone pass the popcorn.
My vote is on awesome. Carry on, and please take more pictures.
Discussion Starter · #12 ·
Thank you for the encouragement, I current have both sides fiberglassed, and one bondod. Once I go buy some more bondo and some sand paper I will get it finished. Was planning in tomorrow, but got go outta town and pick up a new MIG welder(body work is a lil more important). I will get a pic sometime soon.
I would think you wouldn't need the full sheet of MDF once the fiberglass work is completed. With enough sheets of fiberglass it would be strong enough to hold its shape on its own. That is how all of those truck toppers are made, isn't it? From a mold and then remove the mold once the shape is formed.
1 - 14 of 14 Posts
