1 - 11 of 11 Posts
Well, I guess I'm not a fan. I assume you're either going to cut the others to match or replace the one you cut?
What is it that you are unsure of? The stock fender is large and bulky compared to many flat fenders so sometimes the look takes a little getting used to.
I noticed you really cut off a lot of fender with that trim line you selected. You also selected sharp angles which make it look even more narrow. If you just don't like the cut you made they are usually available for cheap on CL.
Fear The Post Count
Discussion Starter #6
Thanks. I had an extra set so I thought I'd give it a try. You may be right, just takes some getting used to. Waiting till my slush fund can afford a set of PS fenders.
I've seen a lot worse. That actually doesn't look bad at all. I'd cut the other side, run it for a week and see what you think.
I actually like it I. Did you have to cut it as much off as you did? It's a lil more narrow than I would go. What did you use to cut it?
1 - 11 of 11 Posts
