Hello, I just repaired my stock CV joint on my jeep about a month or two ago and i didn’t tighten the clamp on it enough so all the grease slip out and not having bad cv joint problems. I was wondering if I could repair the boot again add some more grease in there bc it’s not an old joint. Any thoughts thanks!
If you're lifted odds are the boot will get cut again..and again. I replaced mine a few weeks ago with the Teraflex high angle rzeppa joint/boot. Its basically a reengineered endcap that is wider allowing more range of motion without getting cut. The boot is also thicker. If you have the problem again it may be worth checking out.
