Well... DaddyJeep is starting to show his age and is in need of a bit of a rebuild. I found out that the rear section of the frame was rotted out so I had to replace the last 18" of the frame rails on both sides.
Since I had gone this far, I decided it was time to replace my completely worn out body mounts. Then again, since I had to do that I might as well just tear it down to the bare frame. That is where I am now...starting the tear down. This is going to be a very slow build since I work two jobs and am a Cubmaster for my son's Cub Scout pack. My free time is limited to an hour or two week, if I am lucky. My deadline is to have it ready for the Bantam Jeep Festival next August.
Just to make things a little more interesting...
Thats right...5.2L V8 and 46RH tranny. I am having my local VoTech rebuild the 5.2 for me and need to find someone to go through the tranny for me. I am not much of a wiring guy so this might be a bit of a challenge next spring when it is time to get things back together and running.
If time and money allow there are several other things that I would like to get done during this build. I need to get my tube fenders built, similar to the Metalcloak ones. I need to build a real cage, which I plan on tying onto the tube fenders that will then tie into a front stinger. I want this thing completely wrapped in 1.5" DOM as one solid unit. Of course I have to finish my bumpers and tire carrier. Hopefully by the time all of this is done I should be getting pretty good with my welder.
Here is a pic of my current progress. I have the front clip off and just have a couple of really rusty body mount bolts to cut off and the tub will come off.
I really need to get started on getting the engine out of the Grand Cherokee and get it over to the VoTech before the weather gets bad. My garage barely holds the Wrangler so I will be working on the grand outside. If anyone needs anything off of the grand let me know. All I need is the drive train. Notice those sweet 5 spoke Jeep wheels. I am sure one of you guys could give them a good home. Also, My current Wrangler drive train needs a new home. 4.2L with Howell fuel injection, only 96000 miles.
