The little 4cly was just about done for. had to shift down to go up the smallest IMG_0831.jpg
IMG_0753.jpg of hills on the freeway...so it was time.
the conversion is to a 350, bored out .030 over to clean it up, flat top pistons to take up the compression a bit and a TH-350 trans adapted to the NP231 because the AX5 would not hold the 350.
A full rewire of the Jeep end to end is also in order and to top it off I made a steel flat dash to get rid of the plastic and make way for good gauges.
