Hey! need some more information on swaping my rear end to a dana 44, I was wondering what is the best vehicle to get it out off? I am looking at one from an 03 grand cherokee that has the dana 44, my jeep is an 03 wrangler sport, will this fit? Let me know! thanks:)
Post this in the right forum, and you will likely get more responses... this is the build forum, where people post up about what they've done to their rigs. Your post would be more at home in the TJ tech section.
A moderator will probably move it for you, but I'm just letting you know.
Only a dana 44 from another TJ will be a direct bolt in. Everything else will require some fab work in order to make it bolt on. If you can weld then depending on your area it may be a lot cheaper to find a dana 44 from an XJ and weld on some TJ brackets.
