if i am swapping from a dana 35 to a dana 44, is there anything else i will need beyond the axle itself? is the pinion yoke the same on both axles? will my d35 drum brakes work on the d44?
· Retired Admin/Mod
in theory it should just bolt in place of your d35.. I think even your old drive shaft should work just fine...and the brakes should swap over as well...
· Retired Moderator
Might not be true with the driveshaft. If I remember rightly from others that I have seen done, the snout on the 35 is longer than the 44. So you might have to have your shaft lengthened.
· Retired Moderator
1BLKJP said:
No those are only if you want your shaft hardened. :D :p :eek: :D
But make sure you go to the doctor if it stays that way for more than four hours!!!!:D :eek: :eek: :D
